mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
MrAsker
Oct 28, 2011Tutor
mjw wrote:
ewok wrote:
1. Download the source tarball
2. Build using the "--enable-posix-acls" option
3. Post the ".deb" file in this thread so that I can also try it out
4. Install the resulting deb in your ReadyNAS Sparc development/test environment
Hi,
I've noticed that when making a Backup from my NV+ to an USB drive with NTFS on it the mount.ntf-3g takes basically all the CPU and since I've read that some performance issues have been resolved I would like to try a later build of mount.ntfs-3g. But I then have a few problems since I'm not a developer and not that good at Linux.
A. How do I check what version I have of the current mount.ntfs-3g?
B. How do I perform the 2:nd "Build" bullet in the above quoted list?
C. I assume that installing the resulting file is as simple as making a backup of the existing file and then replacing it with the new file, or is there something else I need to do?
Thanks in advance
