mjw1
Sep 03, 2010Aspirant
[SOLVED] NTFS Operation Not Supported (45)
[PLEASE JUMP HERE IF YOU WANT TO GO STRAIGHT TO THE SOLUTION] I have been struggling with a few permissions related problems and would really appreciate some help: This is my setup: - User mode...
mjw1
Oct 28, 2011Aspirant
Just update to the latest version of raidiator.
You should be able to check the version of ntfs-3g by ssh'ing into your nas using Putty and typing
ntfs-3g -help
