TMcL
Dec 08, 2018Tutor
Sonos cant connect to readynas Pro 4
Getting Nas won’t allow Sonos to connect error. Sonos tried for an hour to help but gave up. I have messed around with shares and permissions beyond my comfort zone. Will the Pro4 using xraid and r...
- Dec 10, 2018
Your product guide is here: https://www.sonos.com/support/en/sonos-user-guide/index.html#t=sonos-user-guide%2Fconnect%2Fconnect.htm
Instructions for playing media via DLNA is here: https://www.sonos.com/support/en/sonos-user-guide/index.html#t=sonos-user-guide%2Fmusic-sources%2Fmusic-sources.htm%23TOC_Play_music_from_UPnPbc-8&rhtocid=_0_6_4_2
Are you able to access your media when you enter \\192.168.1.66 in the file explorer address bar? Note I am assuming that is the IP address of the NAS (not the Sonus Connect).
TMcL
Dec 10, 2018Tutor
I have a Sonos Connect - brand new out of box last week. All firmware updated.
Attached to my Amp.
Ideally the sonos connects to my ReadyNAS on my network and I use an app on my iphone or ipad and never have to use my laptop to play music. But when using my iThing to connect the sonos to my ReadyNas music directory, I received "The computer "Nas-A9-C2-86" will not allow the Sonos to connect."
And because the iphone screen is small and my eyes are old and my fingers fat... I decided to use my laptop to connect the Sonos to the music directory. So I downloaded the sonos software to my laptop (HP Windows 7) and receive the exact same error.
(as well as teh error "The computer "192.168.1.66" will not allow the Sonos to connect." when I try to use the IP of the sonos on my network.)
I have an ATT Modem Router ARRIS BGW210-700
What other info might help?
Thanks, T
