TMcL
Dec 08, 2018Tutor
Sonos cant connect to readynas Pro 4
Getting Nas won’t allow Sonos to connect error. Sonos tried for an hour to help but gave up. I have messed around with shares and permissions beyond my comfort zone. Will the Pro4 using xraid and r...
- Dec 10, 2018
Your product guide is here: https://www.sonos.com/support/en/sonos-user-guide/index.html#t=sonos-user-guide%2Fconnect%2Fconnect.htm
Instructions for playing media via DLNA is here: https://www.sonos.com/support/en/sonos-user-guide/index.html#t=sonos-user-guide%2Fmusic-sources%2Fmusic-sources.htm%23TOC_Play_music_from_UPnPbc-8&rhtocid=_0_6_4_2
Are you able to access your media when you enter \\192.168.1.66 in the file explorer address bar? Note I am assuming that is the IP address of the NAS (not the Sonus Connect).
Dec 10, 2018Guru - Experienced User
TMcL
Dec 10, 2018Tutor
192.168.1.66 is the ReadyNas (not the Sonos)
I am going to have to take a break from this for a bit.
Some time today while trying to update the securtiy settings or something I made a mistake and a brown out occured. Currently I am able to login to FrontView but can no longer see the files on the NAS. This morning I could (I even copied some mp4s to my test share meidasonos).
In fact in just the last 5 minutes I can no longer getinto frontview.
I'll get back to you.
Thanks
Tevia
