sjschmidtky1
May 27, 2020Guide
Specified network password is not correct
I've researched this on both the Windows side and the Netgear side with no satisfaction... I have an older ReadyNAS NV+ with still works well. My problem is access some of the shares. Some shar...
Sandshark
May 27, 2020Sensei
Have you tried resetting the permissions for the files and folders in the affected share? Sometimes a change you have made in permissions does not trickle down to all the files already there, and this fixes it.
- StephenBMay 27, 2020Guru - Experienced User
What firmware are you running?
Are you using share mode security or user mode security?
- sjschmidtky1May 28, 2020Guide
Firmware version is 4.1.16 (which is the latest per the update screen)
My security mode is set to "Share" with a workgroup of "WORKGROUP"
All of my shares are set to "nogroup" for the primary share.
As mentioned, some shares work and I can't get to others on the same NAS.
Thanks in advance for any advice you can offer.
Steve
Another data point that may help with diagnosis.... when I try to delete unused shares, it will not let me choose "apply" and delete the shares. I can create shares, but can't delete them. Does that help?
