vbif
Jun 10, 2019Aspirant
Spin-down problem and how I resolved it
Since the Spin-down option was built in it has been never working properly. After each and every Update (wich I appreciate a lot by the way) I've been trying to activate this function always with the...
Jun 11, 2019Guru - Experienced User
I don't have many of the log files you reference (and don't have /etc/rsyslog.conf either). Normally the NAS logging is done with journalctl.
I am thinking you might have installed rsyslog manually - is that the case?
vbif
Jun 11, 2019Aspirant
that is an interesting point. But I haven't installed rsyslog manually, may be it came with some Netgear apps as a dependence, I did test some of them.
by the way journalctl also writes to the root aka md0
