dhinesh
Mar 18, 2011Aspirant
squeezebox set up for audiophiles
After researching a bit and reading up on the forum, I would like to set up my squeezebox touch as follows and any input, criticism, guidance, etc to help all of us get on the right path would help. I...
dhinesh
Apr 07, 2011Aspirant
sphardy wrote:
dhinesh wrote: Personally I'd recommend you just enjoy what you already have and not waste your time further trying to make the Touch "STRONG"
Guess theres no point in trying to put square pegs into round holes. :D Seems like nothing is going to make a difference. Will post back when I get the linear power supply.
In the meantime, let me share something with you. Put a 10 db and a 6db attenuator produced by mini circuits in the digital line and sound improved quite a bit. Connection: Squeezebox digital out into a 10db attenuator and then into a 6db attenuator and then into the dac, noise level dropped considerably. check out the low down on this: http://www.diyaudio.com/forums/digital- ... ucers.html
tried it and fell in love with the improvement. Things like this keep driving me to look for the perfect set up. But have not got there yet. But if its a futile cause, better save up for a high end product like the weiss 2002........ :? and hope it sounds better
