dhinesh
Mar 18, 2011Aspirant
squeezebox set up for audiophiles
After researching a bit and reading up on the forum, I would like to set up my squeezebox touch as follows and any input, criticism, guidance, etc to help all of us get on the right path would help. I...
dhinesh
Apr 08, 2011Aspirant
[quote="Hickup"]
In that case you still miss the point of the DAC8. The HiFace is a USB to S/PDIF converter, so again, instead of being able to use the superior capabilities of the DAC8's handling of USB based input, you feed something inferior to it which cannot be handled well by that machine.
Tried it and it sounds good. Back to same problem: have to use itunes and small library.
