dhinesh
Mar 18, 2011Aspirant
squeezebox set up for audiophiles
After researching a bit and reading up on the forum, I would like to set up my squeezebox touch as follows and any input, criticism, guidance, etc to help all of us get on the right path would help. I...
Hickup
Apr 08, 2011Aspirant
sphardy wrote:
So in future, make sure you plug your ethernet cable in the right way round, and if the cable runs along the floor, tiptoe as you walk past so that your footsteps don't cause vibrations that could lead to data corruption
Now I know why my WiFi connection is so weak from my PC to my Router! I always thought that I needed to reposition the antenna or buy a better router... I use my ethernet cable in the wrong direction!
I must go home and give this a try, I am sure with this knowledge I can get at least an 31.415926536% increase of the transfer rate - I am happy. I just need to remember that I do not play any music in this room any more, because obviously all these vibrations are harming the data flow as well. This is where these "bad vibrations" must come from you hear so much about.
Kind regards,
Frank
