dhinesh
Mar 18, 2011Aspirant
squeezebox set up for audiophiles
After researching a bit and reading up on the forum, I would like to set up my squeezebox touch as follows and any input, criticism, guidance, etc to help all of us get on the right path would help. I...
dhinesh
Aug 10, 2011Aspirant
the PS for the touch was custom built by an audiophile friend using very high quality components: Black Gate Capacitors (New Old Stock as the factory has closed down), Audio Note and some other audiophile components. Black Gate are famous in audiophile circles, even though the factory closed down, you can still find New Old Stock around. Using the digital out into a DAC. You may want to try a wifi connection between the touch and the router, may sound better
