dhinesh
Mar 18, 2011Aspirant
squeezebox set up for audiophiles
After researching a bit and reading up on the forum, I would like to set up my squeezebox touch as follows and any input, criticism, guidance, etc to help all of us get on the right path would help. I...
lake_eleven
Sep 20, 2011Aspirant
You may want to try a wifi connection between the touch and the router, may sound better
I have disable WLAN on touch. I cannot make this wireless connection as WLAN in SB is a source of noise. I have now setup a hub before the touch. The switch (se2500) is wired to Touch. Switch get internet from the wired router connection. Iam thinking this wired connection could get some noise in to Touch, as router is connnected along with other noisy PSs.
