dhinesh
Mar 18, 2011Aspirant
squeezebox set up for audiophiles
After researching a bit and reading up on the forum, I would like to set up my squeezebox touch as follows and any input, criticism, guidance, etc to help all of us get on the right path would help. I...
dhinesh
Sep 20, 2011Aspirant
wlan is the best of the two evils according to me. You are going to get noise in from the power supply of the switch / router as well. These power supply units are usually switching power supplies. If you connect a linear power supply to the touch and use wlan, the results may be better. I am happy with this set up. The other option is to get a linear power supply for the switch as well. Something not too expensive, perhaps. That way everything is with a linear power supply and this should reduce the noise associated with switching power supplies!
