unoxa
Apr 14, 2023Aspirant
Ssh login in tech support mode on legacy Readynas Pro 2 not working - advice on options?
Following the guide on backing up VPD files on legacy readynas written by Sandshark I could not log in as root when I booted in Tech Support mode, came back connection refused. This on a Readynas pro...
- Apr 14, 2023
You don't use SSH in support mode, you use Telnet.
Sandshark
Apr 14, 2023Sensei
unoxa
Thanks for the rapid reply, will try with Telnet
/Anders Thalme
- unoxaApr 17, 2023Aspirant
Success in using telnet on a Mac running El Capitan (MacOS 10.11), however telnet is removed from never MacOS versions. Took me a while to understand that, but after I moved to an old Mac everything worked.
- SandsharkApr 19, 2023SenseiGood to hear you got in. Not sure why they'd remove a telnet CLIENT, maybe something can be installed in case you need it again? Any Mac users out there know?
