Ger1234
Jul 30, 2017Aspirant
Storage NAS gone?
Hello, I hope someone can help me with my problem. Somehow I lost 92GB of storage in 2 days without copying any files to my NAS (ReadyNAS Duo v2) (I have upgraded the NAS with the latest firmwa...
- Aug 13, 2017
I suggest you use "du -h --max-depth=1 /c/" to investigate where 92GB has gone... should be easy-ish to find I would think.
Jul 31, 2017Guru - Experienced User
So you know what forced the file system check on 7/30?
Ger1234
Jul 31, 2017Aspirant
Yes, I did.
Because my free storage was "drained". I hoped it was a temporary file and maybe a reboot could solve the problem. When I rebooted the NAS I received a pop-up to do a volume scan.
- StephenBJul 31, 2017Guru - Experienced User
I think the next step would have to be some form of data recovery.
https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service is one option, some folks have also reported good results with ReclaiMe.
