tomas1981
Jun 05, 2013Aspirant
Streaming options NV+ v1?
Hi! I'm new to readynas after I got the unit called readynas nv+ v1 (figured out since it is the silver chassi). I've setup the machine and it's seems to work at least when i'm connected with my...
Jun 06, 2013Guru - Experienced User
FTP streaming copies the entire file. If you have subtitles embedded in the file, they are available for the player to display.
Some players also look for a sub with the same name as the media file, and will render them. This is possible with FTP.
I haven't checked on whether AVPlayerHD supports subtitles (I generally don't need them).
I don't understand the connection to the airplay protocol, or which player you are thinking is the native one. Apple's built-in video player doesn't do FTP or DLNA, and it only plays files that Apple lets it play (e.g., mostly managed via iTunes).
