tomas1981
Jun 05, 2013Aspirant
Streaming options NV+ v1?
Hi! I'm new to readynas after I got the unit called readynas nv+ v1 (figured out since it is the silver chassi). I've setup the machine and it's seems to work at least when i'm connected with my...
tomas1981
Jun 07, 2013Aspirant
With the native player I mean the built in video player in iphone. When using the built in player you can do airplay with no problem BUT when doing airplay from another player for instance AVPlayer you will only get sound on the tv. Playing a video with seperate subtitle file I managed to find player handling that through ftp stream and to view it on the tv the only option was doing mirroring which is not so smooth.
