tomas1981
Jun 05, 2013Aspirant
Streaming options NV+ v1?
Hi! I'm new to readynas after I got the unit called readynas nv+ v1 (figured out since it is the silver chassi). I've setup the machine and it's seems to work at least when i'm connected with my...
Jun 07, 2013Guru - Experienced User
You can airplay from other apps. For instance, ReadyDLNA. Though probably it is using the built-in player for playback.
tomas1981 wrote: With the native player I mean the built in video player in iphone. When using the built in player you can do airplay with no problem BUT when doing airplay from another player for instance AVPlayer you will only get sound on the tv. Playing a video with seperate subtitle file I managed to find player handling that through ftp stream and to view it on the tv the only option was doing mirroring which is not so smooth.
As I reported earlier, airplay from AVplayerHD does have issues. Usually you get audio-only, but sometimes it tries to play video and totally fails (with an error message displayed on the apple TV.) You could report this to the app developer, it looks like a bug to me.
