tomas1981
Jun 05, 2013Aspirant
Streaming options NV+ v1?
Hi! I'm new to readynas after I got the unit called readynas nv+ v1 (figured out since it is the silver chassi). I've setup the machine and it's seems to work at least when i'm connected with my...
Jun 07, 2013Guru - Experienced User
It is always challenging in the land of iDevices when you want to go beyond what Apple thinks you should do :wink:
tomas1981 wrote: The problem is that I've tried many player apps (more than 10) like oplayer, avplayerhd, goodplayer etc etc and they all cannot stream video trhrough airplay only audio. I thought it might be a restriction from apple regarding airplay but not sure.
