fearlesss
Sep 29, 2015Aspirant
Stuck on Installing FW X-raid2 Mode
So We've had a NAS RN104 for about 2 years now and have decided to upgrade to the RN204 and I can't for the life of me get this thing to work. It's brand new out of the box for a week. I've got 4 x...
- Sep 29, 2015
Which firmware is this running? You may wish to update the firmware if the unit is running old firmware.
You may also wish to have a look at the compatibility list: http://kb.netgear.com/app/answers/detail/a_id/20641
fearlesss
HI mdgm
I've decided to pull out all the SSD's and put in a 2.5" Hard Drive and it seems to have tempoarily fixed the problem. It has completed the boot process and I can login, Now I'm just going through the process of installing 3 of the SSD's and then removing the HD to replace with the 4th SSD.
Fingers crossed it will all work.
I will jump onto support if this doesnt work though cheers .
mdgm-ntgr
Sep 29, 2015NETGEAR Employee Retired
- fearlesssSep 29, 2015Aspirant
It;s got 6.3.5 Firmware on it which is the latest I think. I upgraded it as soon as I could log into it.
I have checked that list, however it doesn't have any Samsung SSD's on it at all.
I can only assume they just haven't tested any Samsung drives yet, because these are not cheap drives at $350 each
- JennCOct 01, 2015NETGEAR Employee Retired
Hello fearlesss,
Samsung SSD MZ - 7TD120 120GB is the one on the list. I see 250GB as the largest SSD disk capacity it supports.
Not sure if the disk as large as 512GB should work with the fact that the ReadyNAS 200 series is a consumer product.
- StephenBOct 01, 2015Guru - Experienced User
I see no technical reason for it to fail though, since the SATA interface is the same, and the RN200 happily takes 6 TB disks.
Is there something specific about SSDs which is worrying you?
- JennCOct 02, 2015NETGEAR Employee Retired
Hi fearlesss,
512GB should still work with the consumer series 200, it will get faster disk speed. We're waiting for the updated HCL.
- fearlesssOct 05, 2015Aspirant
Yup it seems to be working no worries with all 5 drives now so all good,
Do I have to close this thread or accept it as been resolved ?
