pdasterly
Jul 05, 2015Guide
stuttering blu-ray
Having stuttering problems with my setup, I have rn104 with blu-ray iso files, router is linksys wrt1900ac and media player is kdlinks a300 with gigabit port. Running all cat6 cabling. trying to narro...
mdgm-ntgr
Jul 05, 2015NETGEAR Employee Retired
Well 3D_Movies is on the Disk_1 which is 88%. Ideally the volume wouldn't be that full. If you can copy some of the videos off to another volume to say get Disk_1 under 80% or better yet under 70% full that would be good.
One of your disks is an 8TB archive disk. These are not designed for performance. The 4 GB OS partition is RAIDed across all the disks. So it is possible that the 8TB disk could be related to the stuttering.
I see one of your disks a WD 80GB disk has an ATA error count of 6 though that count hasn't increased since December last year.
You may wish to run the Disk Test boot menu option.
