pdasterly
Jul 05, 2015Guide
stuttering blu-ray
Having stuttering problems with my setup, I have rn104 with blu-ray iso files, router is linksys wrt1900ac and media player is kdlinks a300 with gigabit port. Running all cat6 cabling. trying to narro...
Jul 12, 2015Guru - Experienced User
If ping google.com -f -l 1472 works, then the MTU on that path is 1500 (you need to add 28 to the ping payload size to include headers).
Maybe try pinging the media player using the same command, and confirm its MTU.
