pdasterly
Jul 05, 2015Guide
stuttering blu-ray
Having stuttering problems with my setup, I have rn104 with blu-ray iso files, router is linksys wrt1900ac and media player is kdlinks a300 with gigabit port. Running all cat6 cabling. trying to narrow down whats causing media player to stutter.
Also have router tied to a switch se4008 linksys
- mdgm-ntgrNETGEAR Employee RetiredDo you have a static I.P. set on the NAS? If so did you remember to set the DNS setting?
- using dhcp, dns points to my router
- Had to manually install smbplus, working
- mdgm-ntgrNETGEAR Employee RetiredAnd does changing settings using SMB Plus help?
mdgm wrote: If you install the SMB Plus app and change the settings to e.g. force SMB2 in that does that help?
Can you send me your logs (see the Sending Logs link in my sig)?
i have option smb 3.0, 2.1, 2.0 and 1
which one, u said 2 but 2 or 2.1- mdgm-ntgrNETGEAR Employee RetiredWell try 2.0 and see what that does.
This may not help, but worth a try. - slightly better but there is still some stutter. No logs to download, i cleared them before i ran movie.
side note, your guide to making gmail work, worked. thanks
I was trying lastnite to setup and basically gave up, now it works
Logs sent - mdgm-ntgrNETGEAR Employee RetiredSend the logs anyway please.
- sent
attn:mdgm - mdgm-ntgrNETGEAR Employee RetiredI see you are using a separate volume for each disk. Why is that?
Which volume are the Blu-rays on?
Some of your volumes are very full.
I see you have ReadyNAS Surveillance and mysql running. If you stop ReadyNAS Surveillance does that make any difference?
