LeiNie
May 29, 2012Aspirant
Suggestion: Lost Network Connection (ReadyNAS DUO)
Hi, I have been having the very well known problem where the ReadyNAS Duo occasionally drops its network connection completely - only a reboot cures the problem. This week I found the reason - my H...
May 29, 2012Guru - Experienced User
It should be easy for them to fix, since you have a pcap file which reproduces it quickly.
