Ma2T
Oct 22, 2012Aspirant
Switch or router? ReadyNas duo
Hey guys, I've finally upgraded my laptop with an express card gigabit Ethernet port as I was hardly using my ReadyNas Duo because of the slow 100mbit speed. I have a adsl / router combo, but it...
Etz
Ma2T wrote: But if not, I'll just go with what you use!
Actually 8-port GS608 has a smaller brother GS605, which is 5-port ;)
Ma2T wrote: I'm tempted by the http://www.ebuyer.com/52760-netgear-pro ... itch-gs105 due to it's small size.
Will do also probably (never used it), but specs look good, also metal housing is better for heat dissipation... ;)
Store-and-forward
128 KB on-chip packet buffering
Jumbo frame: up to 9,720 bytes
If you dont care about looks, you could buy that one, also it supports larger frames than GS60x ...
