connor25
Dec 07, 2015Tutor
Switching Drives
Ok here is a scenario, I have a NAS 312 running with an old NAS 102 if they were both running the same firmware, could I effectively switch drives from the 312 to the 102 and it would then work the s...
connor25
Dec 07, 2015Tutor
Ok how about this, if I had 2 x NAS312 Drives 2 Bay's... one was running all the time with a backup USB for safe measure, then the other was empty... if one went down for whatever reason (and wasn't the drives of course) could I simply switch both drives into the other NAS and boot up and use as normal?
Dec 07, 2015Guru - Experienced User
Yes. Though its best to keep the firmware in both units matched. The backup NAS will attempt to reinstall the firmware if the version in its flash is different from what's on the disks.
