themediapot
Nov 12, 2017Aspirant
System volume root's usage is 82%. Mysql seems to be the offender… ReadyNAS 202
Hi there, I have been getting this email alert for the past few days, and have been looking through the forum for past guidance over the last few days. But as of today it has gone to 87% from 80...
Michel-jacobs
Nov 12, 2017Guide
Remove loganalyzer, delete /var/lib/mysql
and peer pressure THE author of the Loganalyzer app to write data to data not to to var
- themediapotNov 12, 2017Aspirant
Thank you Michel-Jacobs. I am pretty sure that I have other programs that uses mysql, like rsyslog.
BTW, do you have an alternative suggestion for Loganalyzer?
- StephenBNov 13, 2017Guru - Experienced User
You can also try moving mysql to the data volume (perhaps replacing the /mysql folder with a soft link when you are done).
