dmahon1
Feb 03, 2013Aspirant
The on-line filesystem consistency check detected problems
I look after two ReadyNAS, both NVX models. They both run disk scrubbing every 2 weeks and file system checks every 8 weeks. One of them consistently gives the error "The on-line filesystem consist...
michno
Aug 26, 2013Aspirant
I'm having the same problem. Weekly check says the check failed, but when I reboot with the check/repair option checked it says no errors were found.
My firmware is version 4.2.24 (I have a feeling this started after the last firmware upgrade).
Michael
Michael
