Rogertheswede
Mar 26, 2012Aspirant
Time machine backup question....
Hello - hope you can help I have two ReadyNAS Duos, both on the latest version. One is primary and the other secondary with backups from one to the other using Rsync over a simple LAN, and all is g...
mdgm-ntgr
Mar 26, 2012NETGEAR Employee Retired
Enable Time Machine on the backup NAS setting the same quota as on the primary NAS then disable it again.
Setup a backup job on the primary NAS choosing "Time Machine" as the source and a new share on the backup NAS as the destination. Use NFS then change to using Rsync.
The Windows/NAS Timestamp should only be used for NAS to NAS backups if one of the NAS units supports neither NFS nor Rsync. CIFS is not a native Linux protocol.
