Gran_Maestro
Sep 25, 2015Guide
Time machine backups last only a few months than need to be started again
Hi everybody, in short: I have been making regular backups using Time Machine for the last 6-7 years I started initially using a Time Capsule and those files are still perfectly ok after quite a few...
mdgm-ntgr
Sep 25, 2015NETGEAR Employee Retired
Which ReadyNAS model are you using and which firmware version?
Which version of Mac OS X?
Are you backing up to the NAS via ethernet or wireless?
No we don't take snapshots of TM backups. Snapshots aren't designed for that.
- Gran_MaestroSep 29, 2015Guide
My ReadyNAS is a model 102 running the latest firmware update, 6.2.5 that is.
2 x 3TB hard disks filling the disk bays.
Connection is via a 3rd gen TimeCapsule and WiFi network access in other words TC is both Gateway to the Internet as well as router of my Local Network.
ReadyNAS connected to TC with a short Ethernet Cable
TimeMachine is active over the air
Macintosh is running OSX 10.10 Yosemite
My apologies for late response, I just got notified of your request a few minutes ago.
Thanking in advance for the given attention
/P
- Gran_MaestroOct 13, 2015Guide
Dear Matthew, would it be asking to much for some follow-up on this issue by you or anybody in charge?
After all, I passed you the requested info two weeks ago, replying should be just a matter of being polite.
I wonder if this bug has been acknowledged by Netgear s/w developers or are you guys just left on your own? If yes, is there at least any kind of bug-squeezing activities carried on in the meanwhile? Just wondering.
It appears to me like this is a real issue affecting more than one customer, I don't think ignoring it is doing any good to Netgear's reputation..
I am not asking for much, at least give us users some kind of hope the problem is being looked into..
Thank you
P
- AlexPeOct 14, 2015NETGEAR Expert
Dear Gran_Maestro,
First, I want to thank you for your patience and your diligence in providing us with the data regarding this issue.
Matthew has been helping us out on some other issues.
Can you forward the logs to me?Send Logs to me
Put in the Subject: ATTN: Alex Timemachine backups issue
Thanks
Alex
- Gran_MaestroOct 15, 2015Guide
Dear Alex, thank you for the attention.
I have downloaded the requested Log file and sent it to the address given.
Hope it helps towards finding a solution.
Regards
Pieter
