nanoamp
Dec 13, 2016Aspirant
Time Machine could not be accessed, network password problem
I'm running OS X El Capitan (10.11.6) and after running the latest set of updates from the App Store (Security Update 2016-003, Safari 10.0.2, XCode Command Line Tools 8.2, iTunes 12.5.4), Time Machi...
- Dec 15, 2016
Hello nanoamp,
Can you please verify also if you are able to access the NAS via SMB and AFP?
Welcome to the community!
JennC
Dec 15, 2016NETGEAR Employee Retired
Hello nanoamp,
nanoamp
Dec 15, 2016Aspirant
Hey JennC,
I connected successfully via both AFP and SMB using a regular user account. I could both read and write files. So, I tried starting a backup using the TM user account, and it worked first time. No other changes. So... good?!
If it recurs, I'll check that I can login manually via AFP first. I can see that'd be a useful diagnostic. Thanks!
