JustKJ
Sep 23, 2016Aspirant
Time Machine slow after 6.5.2 update
It may be a coincidence, but I just updated my ReadyNAS to firmware 6.5.2. I back up three Macs to the TimeMachine i have on the unit. The time machines have worked fine since when I purchased it,...
mdgm-ntgr
Sep 24, 2016NETGEAR Employee Retired
Which services are you running under System > Settings > Services?
Which apps do you have installed?
Which ReadyNAS model is this with?
I think it's a good idea to do a fresh full backup after the annual major OSX update anyway and that's what I normally do.
JustKJ
Sep 24, 2016Aspirant
SMB, AFP, NFS, ReadyDLNA, Rsync, UPnp HTTP HTTPS, Antivirus
Anti-VIrus Plux
ReadyNAS 314
I have not updated past El Capitan latest version 10.11.6
- mdgm-ntgrSep 25, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- JustKJSep 25, 2016Aspirant
The logs have been sent. I will also add to this as it may be a second symptom, that my itunes library is on a volumne, and i ran into problems playing music yesterday, the song kept pausing and then resuming every 5-10 seconds.
- JustKJSep 28, 2016Aspirant
MDGM, I uploaded the logs three days ago, did you recieve them from the common email account?
- mdgm-ntgrOct 06, 2016NETGEAR Employee Retired
Do you still see this issue on 6.6.0?
