JustKJ
Sep 23, 2016Aspirant
Time Machine slow after 6.5.2 update
It may be a coincidence, but I just updated my ReadyNAS to firmware 6.5.2. I back up three Macs to the TimeMachine i have on the unit. The time machines have worked fine since when I purchased it,...
Francysen
Oct 29, 2016Aspirant
hello, order to use hd connects to my router to use time machine, which kind of format type do you use? NTFS? thansj
- StephenBOct 29, 2016Guru - Experienced User
Francysen wrote:
hello, order to use hd connects to my router to use time machine, which kind of format type do you use? NTFS? thansjThis is in the wrong forum - it should be in the WiFi Router forum. Please repost it there, and include your Netgear router model.
Here's a link: https://community.netgear.com/t5/WiFi-Routers/ct-p/home-wifi-routers
