aselke
Oct 16, 2012Aspirant
Time Machine with OSX 10.8.2 & ReadyNAS NV+
I recently acquired my first Mac in several years and I was pleasantly surprised to find my ReadyNAS could act as a Time Machine disk. Unfortunately, after some problems making it work, I tripped acr...
mdgm-ntgr
Oct 17, 2012NETGEAR Employee Retired
To help isolate the cause of the issue you could use a Thunderbolt to ethernet adapter perhaps?
Ethernet is also useful for faster backup speeds and a good choice to use for the first backup which is a full backup.
Have you tried toggling Bonjour off and on again?
Could you check your router's settings to see if it has a setting for multicasting and enable that? There is a possibility your router may be configured incorrectly or may be incompatible with Bonjour advertisements. This post was made a while ago but you may find it useful: http://sphardy.com/web/readynas/apple-services-not-visible-over-wifi/
