hunger
Jul 18, 2013Apprentice
TimeMachine on ReadyNAS Duo with RAIDiator 4.1.12
I was running Time Machine with no problems on a ReadyNAS Duo running what I think was RAIDiator 4.1.8. I updated to RAIDiator 4.1.12 and now the Mac no longer sees it as a Time Machine server. I've t...
PaddyNo
Aug 19, 2013Aspirant
Hi mdgm
Yes, I thought it too, but I set up a 2nd MacBook for Time Machine with "my" procedure and it works perfectly using my workaround.
Again: if you have CIFS enabled during the setup of TM, the wrong address is used. The backup will never run...
Solution: disable CIFS, set up TM on the Mac, run the first backup, enable CIFS again.
