bludevil
Nov 04, 2014Aspirant
Turning RN104 into an external enclosure
Is there anyway I can turn RN104 into an external NAS enclosure - I would like to populate it with 2TB-4TB NTFS disks with data and share/serve the content on internal LAN? Not interested in RAID - th...
vandermerwe
Nov 04, 2014Master
"NAS enclosure"?
There is no way I know of to just use the box as a simple enclosure - for one, the device is connected via Ethernet and has to function as a NAS device.
Just use it as a nas without RAID,turn Xraid off and set up one volume on each disk, the disks won't use the ntfs file system though, but you'll achieve the sharing element.
