bludevil
Nov 04, 2014Aspirant
Turning RN104 into an external enclosure
Is there anyway I can turn RN104 into an external NAS enclosure - I would like to populate it with 2TB-4TB NTFS disks with data and share/serve the content on internal LAN? Not interested in RAID - th...
mdgm-ntgr
Nov 06, 2014NETGEAR Employee Retired
The only way that will work is if you put the disks in USB enclosures and connect them that way. You will need at least one disk that can be put in the NAS and wiped by the NAS to put the OS on.
