Amien
Dec 22, 2013Aspirant
Ultra6 expansion failed
Sun Dec 22 16:20:57 CET 2013 Volume expansion failed Sat Dec 21 12:52:11 CET 2013 Volume expansion or migration started. Do not interrupt the system during this time. When finished, email notifi...
Dec 31, 2013Guru - Experienced User
You could try support - though if you reconfigured the linux OS, you probably should put it back first.
You could also try the off-line expansion procedure here: https://www.readynas.com/forum/viewtopi ... 6&p=356612
Though it carries some risk, so you should back up as much as the non-critical data as you can before attempting it.
