SteveMathews
Sep 04, 2015Guide
Ultra6 Hangs on Boot
Help! For a few days now my Ultra 6 has been hanging on the boot screen. From the boot menu I've done the memory test which seems ok. I re-flashed the firmware - i'm not sure it worked since...
- Sep 05, 2015
Hi, thanks for the suggestions.
Mdgm really kindly remoted into it and fixed it. Apparently it was a corrupted OS partition and he had to create a fresh OS volume.
thanks everyone
Steve
JennC
Sep 05, 2015NETGEAR Employee Retired
Hello SteveMathews,
Make sure when you removed the disks from the chassis you inserted tham all back to thier respective bays, all at the same time.
try skip volume check from the boot menu and observe the status on RAIDar.
Once you are able to access the admin page, download system logs and upload to wikisend.com then send the download link here.
