mdfire
Dec 17, 2017Aspirant
Unable to access Readynas Duo over wifi
I have a readynas duo for a number of years and its never given any problems. I recently changed my router to a netgear nighthawk and whilst i can connect to the readynas over ethernet, none of my wi...
Sandshark
Dec 18, 2017Sensei - Experienced User
Assuming Windows, it sounds like you forgot to tell Windows Firewall that your new home network is a trusted one. That, or the same with an anti-virus program (though most of them act the same for wired and wireless).
- mdfireDec 18, 2017Aspirant
Thanks. Not sure how to do that but will google it. Non windows devices are also not connecting e.g. amazon fire stick. I have an ethernet connected fire tv box and its able to connect but not the wifi stick.
- StephenBDec 18, 2017Guru - Experienced User
That sounds like you might be accidently double-routing.
Can you describe your network? Are you using your router to provide WiFi, or are you using a different device? Are your ethernet devices connected to a switch, or are they connected to your router?
My netgear router is the DHCP server and providing wifi access. There is an ethernet cable from the router to an 8 port netgear switch and from there ethernet to the NAS.
