mdfire
Dec 17, 2017Aspirant
Unable to access Readynas Duo over wifi
I have a readynas duo for a number of years and its never given any problems. I recently changed my router to a netgear nighthawk and whilst i can connect to the readynas over ethernet, none of my wi...
Sandshark
Dec 18, 2017Sensei
Assuming Windows, it sounds like you forgot to tell Windows Firewall that your new home network is a trusted one. That, or the same with an anti-virus program (though most of them act the same for wired and wireless).
mdfire
Dec 18, 2017Aspirant
Thanks. Not sure how to do that but will google it. Non windows devices are also not connecting e.g. amazon fire stick. I have an ethernet connected fire tv box and its able to connect but not the wifi stick.
- StephenBDec 18, 2017Guru - Experienced User
That sounds like you might be accidently double-routing.
Can you describe your network? Are you using your router to provide WiFi, or are you using a different device? Are your ethernet devices connected to a switch, or are they connected to your router?
- mdfireDec 18, 2017Aspirant
My netgear router is the DHCP server and providing wifi access. There is an ethernet cable from the router to an 8 port netgear switch and from there ethernet to the NAS.
What model switch, and what model router?
Did you try pinging the NAS from a wifi-connected device?
