ramzez
Dec 16, 2012Aspirant
Unable to perform a Boot Recovery using a USB flash device
Hi, I'm unable to perform a Boot Recovery using a USB flash device. When I try to Dd to the usb stick, terminal says "permission denied". I have tried three different usb sticks with the same probl...
mdgm-ntgr
Dec 17, 2012NETGEAR Employee Retired
What exactly did you enter? When I wrote "..." I meant for you to write what you did originally.
e.g.
sudo dd if=source of=destination
If using Mac OS X you can drag and drop the source to the Terminal to fill in the path for "if". You can look up in Disk Utility which disk your USB key is e.g. /dev/disk1
e.g.
