lakaw
Sep 25, 2016Aspirant
Unrecognized Channel
Bought a used RN516 off ebay with firmware 6.5.2. NAS came with 5 WD30EFRX-68AXNO HDs with firmware 80.00A80. NAS came with HDs in channels 1,2,3,5,6. I shuffled the HD's to Channels 1-5 (all Disk LE...
- Oct 04, 2016
eBay seller must've known the RN516 was faulty, as he accepted a return even though the auction listed no returns...
Thanks for the help.
lakaw
Understood about the used product.
Seller had 100% positive rating with 345 reviews. Appears trustworthy... I messaged him before I purchased it and he verified it was in perfect working condition. I went and looked through the logs and didn't see anything, but I may have deleted them. Can I just swap the drives again and it will produce the error log.
I just want to verify that there is indeed a drive bay failure before I contact the seller again.
Thanks for helping...
mdgm-ntgr
Sep 25, 2016NETGEAR Employee Retired
What happens when the disk is added would likely show in kernel.log or systemd-journal.log. These logs are rotated over time.
- lakawSep 26, 2016Aspirant
Looks like I spoke too soon on all the drives being good. The last drive resynced late last night and Volume health changed from redundant to degraded showing 10.9TB free. So I'm assuming the last drive sync'd is going bad. I looked at the logs you mentioned, but didn't really know what to look for.
Is there any way you could have a look or guide me in some way?
- StephenBSep 26, 2016Guru - Experienced User
For the last drive, start by looking in disk_info.log.
FWIW I think that when the volume is degraded the system should directly tell you which disk in not in the array. Screen shots like the one above is needlessly confusing.
- lakawSep 27, 2016Aspirant
After reviewing disk_info.log, nothing stands out as being bad. Not sure what to look for, but "ATA Error Count" through "Uncorrectable Sector" count are all zeros.
