slvnews
Oct 31, 2019Aspirant
Unwanted snapshots
Hello I have ReadyOS 6.10.2. I move from old system. So I add 1 drive. Make jbod Then add second drive And copy old data from old drive to /data/ After copy webgui show me all data as a s...
slvnews
Created new share from gui "old_data_dir"
Move by ssh old data from /data/olddata to new share /data/old_data_dir/olddata
problem gone
So, GUI count all data copied by ssh to eg /data as snapshot ?
Oct 31, 2019Guru - Experienced User
It shouldn't.
But NAS shares aren't ordinary folders - they are BTRFS subvolumes. You'll find you can't delete them with rm.
So if you just copied data with cp directly to the data volume, then you did the wrong thing - the folders would have been ordinary folders - and the NAS software might not have accounted for the storage use correctly.
