stevey198321
Nov 01, 2015Aspirant
Updating owncloud
Hi, i am trying to update owncloud on my Netgear ReadyNAS 314 and when i update (from within owncloud admin page) i get the error "Please upload the ca-bundle.crt file into the 'config' directory" ...
- Nov 22, 2015
Right, i got mine working and this is how for anyone who does a search for this error
On the following link right click and press save as, change it from txt to all files and rename it ca-bundle.crt then save
https://raw.githubusercontent.com/owncloud/core/stable8.1/config/ca-bundle.crt
go into your readynas, make sure you have selected to view hidden files
then go to data/.apps/owncloud/web/config/
copy the ca-bundle.crt file into this folder
go back into the website of your owncloud
it should now update
hope this helps
stevey198321
Nov 05, 2015Aspirant
Hi, thanks for the reply,
Currently firmware is 6.4.0
Not tried uninstalling it as i didnt want to loose everything?
Thanks for your help
- JennCNov 06, 2015NETGEAR Employee Retired
