powellandy1
Nov 24, 2014Virtuoso
Upgrade from RN104 to RN316
Hi I have a ReadyNAS 104 (firmware 6.1.9) with 4x4TB discs in a single volume X-RAID2 array. Is it possible, without data loss, to put them in a RN316 and then add 2 further identical 4TB discs to e...
Nov 24, 2014Guru - Experienced User
As I said, this migration path is supposed to work. :D
xeltros wrote: The 104 and the 316 don't use the same CPU type so you can't just transfer the disks like that.
http://kb.netgear.com/app/answers/detai ... -system%3F does NOT say that you need to stay within the processor family.
Though of course you always should have a backup, and it is particularly important when you are playing with disks.
