powellandy1
Nov 24, 2014Virtuoso
Upgrade from RN104 to RN316
Hi I have a ReadyNAS 104 (firmware 6.1.9) with 4x4TB discs in a single volume X-RAID2 array. Is it possible, without data loss, to put them in a RN316 and then add 2 further identical 4TB discs to e...
mdgm-ntgr
Nov 24, 2014NETGEAR Employee Retired
Users have done the migration and it works. There have been some threads on this.
Putting a spare disk (must not be from your array) in the 316, updating the firmware, removing the spare disk then migrating the disks across is what I would recommend.
Of course if you have the time a clean setup is better, especially if you installed apps on the 104.
