Dalo-Harkin
Jan 03, 2020Aspirant
Upgrade of drives due to low space
Hi guys, So my system came up that I am running low on space, I have drives in the following order: 2TB, 3TB, 2TB, 2TB So I purchased a used 4TB WD Red drive, hotswapped it into bay 1 which did hav...
Dalo-Harkin
Hi and thanks for the reply.
Yes it does come up with the format option which I have tried more than once, but there doesn't seem to be a way if you can check this is completed or not?
I put the old drive back in as it wasn't 100% full, and the procedure just started, it went from degraded to syncing and adding the drive back into the pool, which only took a few hours.
I tried the new drive a few times in terms of hot swapping it and rebooting the NAS a few times and it just didn't seem to do anything with the 4TB disk
Jan 04, 2020Guru - Experienced User
Are you using XRAID or FlexRAID?
- Dalo-HarkinJan 04, 2020AspirantXRAID
- SandsharkJan 04, 2020Sensei
Then is sounds like you may have a DOA drive. Have you tried testing with Data Lifeguard?
- Dalo-HarkinJan 04, 2020AspirantNo, I have no way of connecting it to another device
Thank you for the help guys
