Dewdman42
Oct 19, 2015Virtuoso
Upgrade procedure
I am thinking about upgrading my Ultra 2 plus to OS6. I don't have another disk large enough to backup my readynas /c drive ahead of time. I am wondering if anyone has any suggestions for how I ca...
- Oct 27, 2015
OS6 should recognize it.
Though it is actually faster to connect the USB to a PC, and copy over a gigabit network. At least according to the original smallnetbuilder review.
In any event, you should use NTFS formatting, so you have something you can read if the upgrade fails.
Oct 19, 2015Guru - Experienced User
My suggestion is to buy the larger USB drive.
