CJDEN
Jun 01, 2020Apprentice
Upgrade Readynas Pro 6
I'm a happy owner of a newly aquired elderly ReadyNAS Pro 6 running lates OS 6.10.3 in otherwise stock configuration: Intel(R) Pentium(R) Dual CPU E2160 @1.80GH 1 GB Installed Memory BIOS 08/20/20...
viperhansa
Jun 17, 2020Virtuoso
I run in my old pro business with a Intel(R) Xeon(R) CPU X3230 @ 2.66GHz with 8GB ram.
Works perfect, no heat issues.
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 15
Model name: Intel(R) Xeon(R) CPU X3230 @ 2.66GHz
Stepping: 11
CPU MHz: 2659.998
BogoMIPS: 5319.99
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 4096K
MemTotal: 8161912 kB
Bios: FLAME6-MB V2.0
BR
// Hans
CJDEN
Jun 17, 2020Apprentice
I was also considering the 3230. Are you using the Stock fans?
- viperhansaJun 18, 2020Virtuoso
Yes, i'm using stock fans.
CJDEN wrote:I was also considering the 3230. Are you using the Stock fans?
I just picked my cpu from some old project i had..
Fastest possible with the lowest TDP... 95W against 105 on the q6700.
I can't remember the cache size but i think it's a bit larger on the 3230.
