CJDEN
Jun 01, 2020Apprentice
Upgrade Readynas Pro 6
I'm a happy owner of a newly aquired elderly ReadyNAS Pro 6 running lates OS 6.10.3 in otherwise stock configuration: Intel(R) Pentium(R) Dual CPU E2160 @1.80GH 1 GB Installed Memory BIOS 08/20/20...
CJDEN
Jun 17, 2020Apprentice
I was also considering the 3230. Are you using the Stock fans?
viperhansa
Jun 18, 2020Virtuoso
Yes, i'm using stock fans.
CJDEN wrote:I was also considering the 3230. Are you using the Stock fans?
I just picked my cpu from some old project i had..
Fastest possible with the lowest TDP... 95W against 105 on the q6700.
I can't remember the cache size but i think it's a bit larger on the 3230.
